It is currently Thu Feb 27, 2020 2:42 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2, 3  Next
 SketchBook
Post Re: SketchBook
hi
what is that? look like someone's dear hair get stuck to yoyo! i wonder why you create this design.
Wed Mar 30, 2011 10:29 pm
Post Re: SketchBook
saveTheBees wrote:
nice work! any videos of the tests to share? :D
The videos never went through post work so it would be quite different from the image you see.
titusphilip wrote:
hi
Hi there, that's just a learning process... nothing in particular. It's just to try my hand on the hair system.
Btw, I am curious to see your works too guys.
Thu Mar 31, 2011 12:32 am
Post Re: SketchBook
hi sketch,
my work still got some problem to iron out.i will post it once i solve those problems.
Thu Mar 31, 2011 7:39 pm
Post Re: SketchBook
Some water test. Fluid sculpted from zbrush using zsphere and zsketch. rendered in 3ds max.
Wed Apr 20, 2011 5:24 pm
Post Re: SketchBook
ah you must have noticed this then:
http://www.zbrushcentral.com/showthread.php?t=125046
looking good!
Portfolio: http://aaron-animations.com/
3D Printing Shop: http://www.polychemy.com/
Wed Apr 20, 2011 8:47 pm
Post Re: SketchBook
thank. and yup, that was one of the motivation. I know it can be done long ago just never knew it was that easy. You should try it too.
the shader is the troublesome thing. still not getting the shader right yet.
Thu Apr 21, 2011 12:08 pm
Post Re: SketchBook
Nice :) Kinda makes me feel thirsty..
Did you do any post work? Seems there's some chromatic aberration on the liquid. Or is it just glow?
Thu Apr 21, 2011 12:23 pm
Post Re: SketchBook
Im doing something similar for a project actually.
for the shader, if you are using the A&D mentalray material, play around with the Max Distance under the advance reflection tab. This gives a nice colored liquid.
* The values are based on your scene scale.
Good Liquid needs a good Env, to catch reflections. You can just put in white planes (to cast reflections) to help improve the look.
gd luck
Thu Apr 21, 2011 2:07 pm
Post Re: SketchBook
Hi
savethebees,
thank and CA was done in post.
aaron,
I'm using Vray. I did use white planes... in fact, I used the white planes to project lights. Other reflections include the environment and HDRI. thank anyway.
Thu Apr 21, 2011 3:43 pm
Post Re: SketchBook
Here's a practise sculpt.
ImageJoke of A Sculpt.
The painting is a little pixelated as I forgot to increase the subdivision before painting.
Tue Jul 05, 2011 7:12 pm
